Same reason 12 gauge is yellow-- easy for the inspectors to verify what type of cable you used. And you, yourself--- "Hey, apprentice! That should be the 'yellow' cable!"I would have bought every reel they had. What's the purpose of going to blue?
#14 is already white. That's also different than yellow, wouldn't you think? There is no code rule for the color of NM cable!Same reason 12 gauge is yellow-- easy for the inspectors to verify what type of cable you used. And you, yourself--- "Hey, apprentice! That should be the 'yellow' cable!"
Blue has been available in my area for at least 2 years. To my knowledge there’s nothing different except the color.Wonder if the blue is a clad. 14-2 clad for use on 10 amp lighting circuits. Or would it be a different voltage rating. Has to be a reason
I was looking, and they have 14-2 in blue also, but haven’t seen any in my area.Could it be to identify it as 14-3?
I will see if I can find some that it exposed that I could get a name off of it. The only exposed is in the cellar laundry room which is very small, but the panel is in there as well.That's odd. Cerrowire started color coding 14-3 as blue and 12-3 as purple, but the 14-2 is still white.
Why does NM cable need to be identifiable just by sight?I think it is maybe to help differentiate at a glance the three wire cables since they are flat instead of round anymore.
12-3 is usually somewhat easy but flat 14-3 is a little hard to differentiate from some older 12-2 with white sheath.
Makes it easy on the inspectors to spot violations.Why does NM cable need to be identifiable just by sight?
Yes they can, if it’s written into the local regulations.Only if you follow the color code, and they can't demand that.
It is not an NEC requirement.Why does NM cable need to be identifiable just by sight?
