We build Industrial Automation Equipment, and have had several NRTL inspections over the years to have our custom control panels inspected to UL508A. We had our first experience yesterday where our panel was failed by a UL inspector because we drilled and tapped or drilled through the enclosure to mount the nameplate and other Electrical items such as internal Lighting and a Ground Bar. His reasoning is because the hardware we were using is not a listed component that is certified to meet TYPE 12 by UL. Therefore, the Enclosure rating needs to be derated to TYPE 1. Has anyone else run into this? Has anyone ever found listed hardware, nuts, bolts, etc. I get the concept of sealing washers for conduit entries and such but an M3 bolt that affixes a nameplate to a control panel door?
