TwoBlocked
- Bradford County, PA
- Industrial Electrician
Looks like I will get involved with AB PLCs. I am experienced with Modicon so the programming learning curve shouldn't be very long. But from some discussions I've had, going on site to an unfamiliar AB PLC sounds challenging, especially if HMIs are involved. This would be for troubleshooting and minor changes.
So here are my questions:
Is it true that the revision of the software on your laptop must match the revision of the firmware in the AB PLC?
If you update the revision of the firmware in an AB PLC, can it cause problems with other devices connected to the PLC?
How many different kinds of cables are there for connecting to these PLCs?
What are the options for programming software? I would want to be able to connect to any AB PLC product, even if it takes a couple different software programs.
Is there a GOOD, dedicated Forum out there somewhere that would be more helpful than here? (Haven't seen much I like out there.)
I better stop there for now. I've talked to a distributor who seems knowledgeable and helpful but am not sure I really understand what I need to know.
