Not a rule but a UL listing for a cast iron box with threaded hubs for use with rigid conduit.What rule?
The boxes have to be weatherproof.I'd say it depends on the reason it needs to be cast; conductivity, thread sealing, strength, etc.
But probably not. The rule was made when cast boxes were metallic.
Whichever one is the cause of why you're asking.What rule?
But PVC FD boxes are more weather resistant than metal ones.That one.![]()
The reason is that we already have many PVC boxes installed and we see no reason why they have to be metal. PVC boxes are a lot better to keep the water away.Whichever one is the cause of why you're asking.
I try to find the definition of "cast" in some dictionaries. Most of them mention "pouring" the material in the mold but others only mentioned an object shaping in a mold. I agree that the term "cast" is typically used with metal boxes.I thought that PVC boxes were manufactured by a mold injection process. Not sure if that's actually a casting process. Regardless I think that most would agree that when requiring a cast box it not intended to be PVC.
As an FYI, the Merriam-Webster 11th Collegiate Dictionary is the “official” dictionary for non-NFPA common terms.I try to find the definition of "cast" in some dictionaries. Most of them mention "pouring" the material in the mold but others only mentioned an object shaping in a mold. I agree that the term "cast" is typically used with metal boxes.
Wellll.... they're probably injection molded... gooey plastic squirted into a 2-part mold, where it cools. Once cool enough to hold its shape, the mold opens and out comes the molded (not cast!) part...The problem I have is a project where we have already installed a lot of PVC FD boxes. Specifications asking for any kind of box, including non-metallic boxes, but a little note in the plan says we have to use "cast FD box". It does not say metal, or cast iron or aluminum.
I know "cast" is normally referred to metal boxes, iron or aluminum, but my question is if also you can consider a PVC box as "cast" by definition, because it is technically a "cast" box in its manufacturing process.
I really think you are obsessing too much over this. Nowhere do the specs say anything about the material the box needs to be made of. You already installed a lot of PVC FD boxes. Has anybody ever called you on them saying they are not cast? If somebody actually does at some point just say, oh yeah, of course they are cast. How do you think they are made? Then walk away.The problem I have is a project where we have already installed a lot of PVC FD boxes. Specifications asking for any kind of box, including non-metallic boxes, but a little note in the plan says we have to use "cast FD box". It does not say metal, or cast iron or aluminum.
Which of you is late to the party? If the electrical engineer had this on the plans or specs you bid to, shame on you for not paying attention. If the engineer is making this a requirement after the fun began, have him sign your change order and be about it.The PVC boxes were provided by the equipment company. We simply install the boxes and run conduit and cables. We can assume that this company has done this type of work many times before without problems, but the electrical engineer is asking for things above and beyond for no reason. Now we are in the dilemma of replacing the boxes or fighting against the "requirements".
