Tlough
- Burlington NC
- Electrician
I have a barn i would like to connect to a portable generator as the sole power source. The generator is un-bonded and I understand you must bond at the first means of disconnect, in this case is the generator. If I place the bonding jumper at the generator will I need a ground rod? And will that ground rod be at the panel or at the generator? being that I am using an extension cord into a power inlet box then into the panel. Will i not use a ground rod since i am using an extension cord technically, and with adding the ground rod could cause a potential shock hazard.
