Alwayslearningelec
- NJ
- Estimator
When installing a pull rope in conduit that will have 4 #600 would you use 1/4" or 3/4" and why? Thanks
Definitely not 1/4". As Rick stated a double braided rope is best. We typically have many different sizes from 3/8" to 1" depending on the size of the conduit.When installing a pull rope in conduit that will have 4 #600 would you use 1/4" or 3/4" and why? Thanks
1/4" is fine. For very long runs maybe 3/8" cheap poly rope.I was wrong sorry. I meant the drag line used to pull the rope in. That is 1/4".
I only started using tape a few years ago. I like it a lot. Much mle compact and lighter to carry around. Much easier on PVC 90's, although I have never burned through one with regular rope.Never used mule tape in almost 40 years. Must be a regional thing. We never used anything but rope.
That is one of the 5 basic knots we learned as Big Scouts many years ago. While in Viet Nam because I was the commo guy ( I installed telephones ) I got stuck on a detail installing cut in halve telephone poles into the ground to hang fence & barb wire. We would used a big wrecker truck to lower poles into the ground. Ropes keep slipping because nobody but me know how to tie a clove hitch around poles then a few halve hitches every foot. Best knot failures when going night fishing on a party boat and when guy who tied his own knot on a heavy hook caught a huge blue fish. Got it up to the boat and knot failed.Use a sheet bend to tie different sized ropes together.
You can also use it to attach a rope to a sheet or tarp.
A bowline knot is basically the same knot, but with a single line.That is one of the 5 basic knots we learned as Big Scouts many years ago.
We get directional boring crews that bore in HDPE with pull tape already installed in it. I generally keep that tape as it comes in handy for other pulling applications. Doesn't burn through PVC elbows nearly as easily as regular rope does.I only started using tape a few years ago. I like it a lot. Much mle compact and lighter to carry around. Much easier on PVC 90's, although I have never burned through one with regular rope.
It's nice it won't burn through 90sNever used mule tape in almost 40 years. Must be a regional thing. We never used anything but rope.
