JovialBulge
- New England
- Automation Dude
I have a machine where the end user is looking to having the electrical system NRTL certified in the end and I want to make sure I am starting off of the right path here while determining the components that I will use in the machine on the automation side. With regard to proximity sensors, transducers, pressure switches, safety sensors, magnetic reed switches; I assume that I must only use devices that are UL, FM or ETL certified in order to adhere to the NRTL requirement is that correct? If I were to find a device that is say only listed with an ATEX Zone rating I should stray away from using that since, based on my limited understanding, that’s not covered under the NRTL umbrella.
