designer82
- Boston
So I did an optional and a standard service load calc. The standard resulted in a higher service size than the optional.
Either I did something wrong or this is something that isn't uncommon.
If it is something that isn't uncommon, which method would you select the final size based on... the more conservative (standard) or less conservative (optional)?
Thanks
Thanks
