jlack
 - Sheboygan Wisconsin
 - Construction Consultant
Good afternoon,
The insurance industry is questioning "should we insure an apartment or condo complex that has aluminum wiring. I would appreciate any wisdom on these questions.
Can Aluminum wiring be used between the meter pedestal feeding the panel? Code #?
Can Aluminum wiring be used between the main panel feeding the subpanel? Code#?
Can aluminum wire be used in 120 volt branch circuits? Code#?
Is pig tailing acceptable?
Can COPALUM connectors be used?
Can AlumiConn be used?
Is there any method that should not be used?
Thank you,
John
Thank you,
John
