bbcleanenergy
- San Jose, CA
- Solar Designer
I am trying to figure out how much inverter ampacity I can tie in on the load side for a 'Square D ALL-IN-ONE combination Service Entrance' panel. Based on the model number:
Not sure if I am even thinking about this correctly, I have not seen this type of configuration before....
SU3040D-00CB
(from what I can make out, it is a bit scratched off) I think this may be a 400A rated bus bar panel. There is both a 200A and 100A service disconnecting breaker (single meter). With this configuration would I be able to tie in 180A? 400A * 120% rule - combined 300A main OCPD? Or in the case that it is a 300A bus, could I tie in to the 100A section (slots 9-15) to tie in 260A on the load side?Not sure if I am even thinking about this correctly, I have not seen this type of configuration before....
