GarwoodV6
- Houston suburbs
- 30 year commercial Electrician
I have a 30 KvA 3PH 240D in 120/208Y out dry type XFMR in storage that was about half submerged by flood water. I read another thread here about drying out 1PH XFMRs (battleship North Carolina) by using a variac or AC welder connected to the primary winding and shorting the secondary in order to warm the coils to bake out the water in the winding insulation layers by applying low voltage and monitoring/limiting current. I have only one 0-150V variac with 10A max rated output. Can I power up one coil at a time on this 3PH XFMR to accomplish this, provided I keep the variac voltage low enough to limit the variac output below the 10 amp rating on the variac? What about the other two primary and secondary coil sets while I do this - leave them open, or shorted?
