david
- Pennsylvania
Should the hospital grade rec. Be left alone, The rec for the branch circuit is not hospital grade.I think we have. What is your question?
The dot just means it is built to HG strength, they are not just for patient care wiring methods. I worked at one hospital that only stocked HG receptacles and used them everywhere, even outside.Should the hospital grade rec. Be left alone, The rec for the branch circuit is not hospital grade.
You can't install a three prong rec in place of a two prong rec because the equipment ground is compromised usually non existent.
If you have a hospital grade rec isn't the green dot indicating a certain standard of equipment grounding. Supplying that rec?
