WireNut311
- NJ
- Electrician
On my power post for the pool I plan on having 20a twist lock, switch for twist lock (on load side of timer), general purpose rec., and timer
This isn't for a disconnect, that's what the twist lock is for technically. This is for backwashing. I can't decide if i want to use the mech. timer to turn pump on and off, or put in a switch. I think adding a switch is slightly easier. What do you guy thinks?
