Hey folks,
Question re ceiling outlet boxes for the code experts here!
I am installing several LED strip lights in a roughly finished residential basement. Customer has requested cables to be routed between joists above the ceiling drywall versus running surface conduit. So I plan to locate outlet boxes behind each light and pull cable between each location.
The strip lights will be mounted directly to the ceiling joists (not from the box) so ideally I would use something like the Raco 297 old work pan or even an old work 1 gang device box behind each light.
However it seems that 314.27 requires outlet boxes used for ceiling lighting to be specifically designed for purpose (rolling out a regular 1 gang device box) and capable of supporting 50 lbs (ruling out the Raco 297 which is rated to 6 lbs). This seems crazy since the boxes will not be supporting anything since I'm fixing the strip lights to the joists, and there is no way that a 50lb light will be installed in a basement with low ceiling clearance.
Am I reading that section right? Is there any get out? Thanks for any pointers...
Noel
Noel
