Alwayslearningelec
- NJ
- Estimator
FIFYAn online search for "track current limiter" will pull up multiple brands. These are used to comply with International Energy Conservation Code wattage caps for lighting until final inspection, after which they are removed
I've pulled at least a dozen watt limiters out of ceiling fans for customers. The manufacturers are getting pretty good at hiding them. A couple of them I had to dissemble the entire motor surround to get to the limiter.FIFY![]()
What is the purpose of the limiter in the ceiling fan?I've pulled at least a dozen watt limiters out of ceiling fans for customers. The manufacturers are getting pretty good at hiding them. A couple of them I had to dissemble the entire motor surround to get to the limiter.
Right so why would someone need to remove it? I would think that with a LED replacement for an A style lamp there would be enough light even with the limiter.Presumable to limit the lighting load of any built-in/on lights.
Older fans- limit the wattage so people wouldn't put 100 watt bulbs in all three lamps.What is the purpose of the limiter in the ceiling fan?
