timmermeier
- alton il
- electrician
Can i use xhhw in conduit?????????????????????????????????????????????????????????????????????????????????????????????????????????????????
111, actually.So, is 100 characters still the magic number? I ain't countin' those question marks.![]()
Why?111, actually.
Opening posts require at least 100 characters to weed out automated spamming.Why?
Interesting. I never knew that. Thank youOpening posts require at least 100 characters to weed out automated spamming.
Is that the reason, very interesting. We've asked to have it lowered to a smaller number of characters but we've been told that it's the software minimum. For the record you never really see any spam here because all posts by a new poster are screened by a moderator.Opening posts require at least 100 characters to weed out automated spamming.
At times it does keep us busy behind the scenes.Our heroes:
Metric!111, actually.
No, but you can use white text to hide extra characters such as periods.Every now and then I am required to hit the magic number. I never count but figured out blank spaces don't count.
I see the exception to roof top derating unique to XHH?, but notzing else.Yes, it's mandatory for Isolation Power Systems
Well it's hard to find the exception to notzing else.I see the exception to roof top derating unique to XHH?, but notzing else.
Use cable with the best insulation possible. The insulation on the cable should have a dielectric constant of 3.5 or less and, in this regard, all XHHW wire is not created equal. Square D recommends Rome Cable brand, catalog number VW-1 XHHW-2 Spec 2110 because it seems to consistently give the best results. The particular wire you are using may be listed as having a dielectric constant of less than 3.5, but wire manufacturers generally do not list an absolute dielectric constant. So you don?t know if the wire?s dielectric constant is 3.49 or 2.49. Wire insulation types THHN, THHW, THW, THWN and TW are not suitable for use on isolated power systems.
Do not use wire pulling lubricant of any kind on the branch circuits. Wire pulling lubricants tend to change the dielectric of the insulation. If in doubt about the ability to pull-in the conductors, use a larger conduit. The insulation on XHHW wire is thicker than THHN and not as slippery. So plan ahead and ask you distributor for some wire samples.
