In 110.26(C) Entrance to and Egress from the Working Space for Large Equipment requiring an entrance/exit on each end of the working space if
1) the equipment is over 6' wide and rated 1,200A or more
Question: is this referring to a single piece of equipment or collectively? For instance, if a room has several equipment 10' wide but only rated 1,000A or if a room has several equipment 5' wide but each rated 2,000A, would either of these rooms need two entrance/exits?
2) the equipment is the service equipment, is over 6' wide, and the sum of the service disconnects is 1,200A or more.
Question: is the width collectively or for a single service disconnect? For instance, if the sum of the service disconnects are 2,000A yet each service disconnect is less than 6' wide, would two entrance/exits be needed?
