Hello,
I've got another motor calc that I have done and just want to make sure I am interpreting the code correctly.
We are going to be swapping out a old compressor for a new one. Details below.
Old compressor and circuitry.
5HP
23FLA
40c
RPM 1750
Ser Fac 1.15
#8 thhn on a 40amp qo standard trip beaker.
New compressor
7.5HP
FLA 33
40c
Rpm 1750
SF 1.15
According to 430.248
7.5HP = 44amps @ 208v
430.22 44 x 1.25 = 55Amps
Table 310.16 75c. 6 awg thhn
430.52.... Using Standard trip QO breaker.
Do we use the nameplate for the FLA or 430.248 FLC for the breaker?
If we use FLA then 33 x 300(non time delay)= 99 MAX (100) and 33x1.25 41.25 MIN (45) (per table 240.6)
Or if FLC 44 X 300 = 132 amp MAX
44 x 1.25 = 55 amp min
About a 200 ft run, VD 33amps at 208v 3.08% VD.
Plan on coming out of panel with 3/4 emt then switching over to 6/2 MC above grid ceiling then go up to the roof perlins and strap MC for about 130ft inside the garage then set a box and then go down the wall to disco, then flex over to compressor. I had planned on using a 45 amp breaker if we use fla or a 55amp breaker if we use flc for 430.52.
The motor has its own thermal overload.
Thanks!
5HP
23FLA
40c
RPM 1750
Ser Fac 1.15
New compressor
7.5HP
FLA 33
40c
Rpm 1750
SF 1.15
Thanks!
