marmathsen
- Seattle, Washington ...ish
- Electrical Contractor
I'm curious how often others find that lugs break or strip out when using a torque wrench prior to reaching the rated torque value. I of course double and triple checked the setting on my wrench. The wrench isn't more than a year old, but I'll admit it is an inexpensive one from Home Depot
I've had this happen a couple times recently and if I'm in the middle of a service change (Residential) it's a real pain in the butt. The last ones took two weeks to bring in.
On a related note, when I recently used this torque wrench I needed to torque to 275 in lb (~23 ft lbs) So I started at 20 ft lbs (Click!), then moved to 21 ft lbs but it Clicked without moving the bolt, moved up to 22 and again clicked without movement, and same with 23 ft lbs, no movement. So maybe it's my wrench? I've never torqued lugs this way before, I always just set the wrench and tighten 'til it clicks.
So maybe my questions should be:
How often to you see lugs fail below their rated torque values?
How often do you see torque wrenches get out of calibration?
Do you find that inexpensive torque wrenches just aren't worth it? I used to have a Wera but after it was stolen out of my van I bought a...Husky
