Need to pipe into an outside hot tub that is going to have a composite type decking material installed around the perimeter.
Can an LB fitting be placed under the decking?
It would be accessible by physically removing a couple of the “planks”.
The type of fitting that’s on the tub exterior and the interior make up of motor/ pump compartment doesn’t allow for a pull through of the wires without a LB.
Thanks
Thanks
