Hello Everyone,
What size of disconnect can be used for 300HP air compressor (NP FLA= 325A, with S.F.: 1.15)? My understanding the 400A HD disconnect is only rated for 250HP. The disconnect is not used for controls (On/Off) as it has it's own controller. The NEC tables indicate the FLA for 300HP is 361A. Questions:
1. Can I size the disconnect switch based the name plat of the motor X S.F. (325A X 1.15 = 374A- which means I can use 400A HD Disc sw) or it needs to be rated for the motor HP, whch means I have to use 600A since the 400A disc is only rated at 250 HP?
2. Can I use the FLA name plate (325A) for sizing or I must use the NEC FLA (361A)
Thank you,
Thank you,
