Alwayslearningelec
- NJ
- Estimator
Came across this old thread. So if you had EMT with circuit out of a panel to a box right outside the closet then switched over to MC cables out to a hr box in the field would you consider the MC cable "homeruns"? Thanks.
"'Homerun'" definition
Hello all, New to the forum. I'm also new to being an estimator. Working on a bigger project so I need to make sure I'm taking this off correctly. Engineer is allowing MC cable for branch circuits, but not for Homeruns. 'Homerun' isn't defined in the specs, and I know the NEC doesn't define it...
forums.mikeholt.com
