Hello. I have a Sandwich heater machine (Max circuit requirement 40A), should i size breaker per that or by 125%. I'm thinking of sizing the breaker by 1.25 to 50A, especially since the plug is rated for 50. But it also says (max circuit requirement is 40A) - im not sure if that means FLA or Maximum breaker. The wires will be rated for 50Amp anyways, but should i size the breaker for 40A or 50A?
Thank you,
			Thank you,
