Coachmike
- Morris County, NJ
- Electrical Contractor
Have 4- 4" PVC feeders with 4- 750 MCM CU in each. Need to put a 250 MCM CU ground in each. Any ideas? TIA!
Did you just forget about grounding?Have 4- 4" PVC feeders with 4- 750 MCM CU in each. Need to put a 250 MCM CU ground in each. Any ideas? TIA!
I believe this is related to the other thread where they're inserting a service rated ATS in the existing run making the condutors a feeder and not service conductors.Did you just forget about grounding?
the point of service is relocating from the switchgear to an ATSDid you just forget about grounding?
