The title says 2-wire the OP says 3-wire?Welcome to the forum.
Are looking for one line and the neutral, or two lines and the neutral?
Okay, so what kind of panel are you looking for? One L-N inverter just needs a single-pole switch.sorry 2-wire one hot and one neutral. I have an inverter that’s that is only has a 277V output.
I didn't realize you had multiple circuits. I understand a lot of this, but have little experience.It’s a sizable inverter, has around 12 circuits. The output feed was suppose to be 480/277 trying to see what options there is.
Now it makes sense.It’s a sizable inverter, has around 12 circuits. The output feed was suppose to be 480/277 trying to see what options there is.
Is this a solar inverter? What inverter do you have that has single phase 277v output and 12 DC inputs?sorry 2-wire one hot and one neutral. I have an inverter that’s that is only has a 277V output.
Sounds like an emergency lighting inverter which uses batteries, nothing to do with PV.Is this a solar inverter? What inverter do you have that has single phase 277v output and 12 DC inputs?
