Sjo cord in pvc
JJWalecka
New England
Have an injector pump with four float switches and two motors sjo. The plan that was discussed was a hole in the 3.5 foot cover...with Bell end down from LB..up the wall with PVC to injector pump controller.
Is it legal to run the sjo cord up the 2" pipe? Should I remove the sho cord sheath as it enters the 2" bell end?
Appreciate your insight
If it is legal to use cord in this application it is legal to sleeve it in whatever hollow material you want.
No need to remove the sheath.
These motors are less than 300V?
It’s a sleeve, not a conduit. If the pump comes with the cord, it’s meant to be used that way.
As I've read on here before if the code doesn't say you can't then you can.
