Jimmy7
- Boston, MA
- Electrician
Do you determine voltage drop by the actual load? Meaning, if I ran a 120 volt, 20-amp circuit I determine the voltage drop off the actual load, not the 20 amp ocpd correct? If this is the case, for design purposes how long can you run the following
1. 20-amp 120 volt circuit for receptacles (When you're not exactly sure what is going to be plugged in)?
2. 15-amp 120 volt for receptacles (When you're not exactly sure what is going to be plugged in)?
