joshfromoshoto
 - Wyoming
 - Electrician
This may seem like a dumb question, but I am unable to test it. Will you read voltage from a hot leg, to a completely separate grounding system or neutral? My thought is say you were to drive a ground rod and not bond it to anything, if you were to put voltage to the ground rod it would not cause an arc nor would it likely trip any breaker, and from the hot leg to the ground rod you shouldn’t show any voltage. But if we take it further and have an entirely separate grounding system, not bonded at any point to the source voltage would the voltage read on a meter?
