fastline
- midwest usa
- Engineer
I've read conflicting info on drilling the backside of an LB for screws, but regardless of code, they need to be secure! Sometimes I try to bush then in place from the inside, but I typically use Butyl rubber for a long life seal and it needs good compressor to do the thing.
Corrugated steel is always a challenge. No flat surface to work with, and if you are drilling holes, you are only going into sheet metal most of the time....I guess unless you install threadserts or something.
