4.16KV-480V transformer feeds a 480V panel located in a different room. The 480V panel has a main breaker.
1) Can the 480V panel's main breaker be used to protect both transformer secondary conductor and also panel load?
2) If the panel and transformer above are located in same room but 30-40 feet away from each other - within sight,
does the xfmr still need secondary conductor protection, which code section requires this protection? Any exemptions?
