electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Probably a long shot, but anyone have experience with this fault on this or similar unit?  Its a circa 2007 unit.  It cranks for about 4 seconds, just starts to fire then stops with a overspeed fault.  I am nearly certain that it is not actually overspeeding.  I tested the speed sensor and both tests pass with the 1.3-1.9 k ohms and 1.75 VAC minimum while cranking.  I am leaning toward it being the controller, because when I disconnect the gas so the unit does fire at all, it cranks for about the same 4 seconds then stops with an OC (overcrank) fault and does not try again.  According to the service manual it is suppose to crank for 15 seconds, stop for 15 seconds and do that 3 times.  Apparently that is built into the controller and is not adjustable.
