electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Just a thought experiment here. Say you have a lot of cheap/free/extra modules and you want to heat water. Lets say also that you have grid power but cant backfeed or have already maxed out your backfeed. What is the most economical way to do it? Directly connecting modules in series to a 240V (or whatever) heating element would seem to be simplest, but of course you take a big hit by having no optimization of the PV power curve to the heating element. I guess you would size things to get peak output on sort of an average sunny day. An improved option might be to make a up a controller and contactor that will give you two "Settings', sun and shade. Is there a cheap (LOL) MPPT controller that would do this? They make "linear current boosters" for panel direct pumping applications, but they are pretty lower power. A MPPT off grid charge controller (such as the xantrex or morningstar 600V) connected to a small battery with a diversion controller is a nice setup that I have used before, but gets kinda pricey if we are talking about a dozen KW or more. I just keep running into any sort of MPPT controller not being worth it. Ideas?
