Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
Many years ago when I was a mobile mechanic working in automotive electrical systems, I wandered how I could make lighting on a house dim when jumping a 2000 Ford f450 7.4l turbo diesel with my 12 volt dc 200 ampere jump box for the trucks dc starter motor but yet not trip the household breaker for the receptacle circuit rated for only 20 amperes AC?
Hypothetically, what in the conversion process from AC to DC allows this to work?
If comparing power in both circuits (ignoring power factor, impedance, reactive qualities) you have
AC
120 volts x 20 amperes = 2400 VA on AC side of circuit
And
DC
12 volts x 200 amperes = 2400 VA on dc side
Although power whether in VA apparent or watts with power factor, I understand power is consistent in both but are not the AC household breakers rated to trip from excessive amperes current rather than power VA and WATTS?
I also understand that breakers have an inverse trip setting which would make me think the dc jumper would cause the breaker to trip thermally
I guess the equal power is the reason but I thought this was an interesting subject
AC
And
DC
