Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
I install mostly Generac, but I’ve worked on Cummins and Kohler.
I installed a new Kohler the other day. Design is pretty sad from an installation standpoint.
First, manual looked like it was written by an 8 year old who was mad his mommy made him do his homework, so he did the least possible.
You have disassemble the entire housing in order to access the anchor points, and which time to lid is barely hanging on.
Worst part in my opinion, is the location of the electrical inlets. The only way that I can see to enter the unit, is with an LB and chase nipple, otherwise the lid won’t open all the way. Can’t come straight out with flex, for example.
It would get tricky if you use a preformed pad and have to come out tight to the unit, and then go over far enough to clear the pad.
You have to use a minimum of 2, and sometimes 3, conduits and entries. You can’t use the GenCable like Generac.
The design of the entire electrical compartment is one of the dumbest things I’ve ever seen. You can’t access your LB with the lid up, and you can’t access the electrical compartment with the lid closed. I’d like to slap whoever came up with that design. Feeding the conductors in is not fun.
And the placement of the main breaker is equally goofy. Its aimed the wrong direction so you can’t see what you’re doing.
I know they are good units and have a reputation, I’m not sure which is better. I’ve removed cummins and replaced with Generac because they had issues with Cummins and never had problems with Generac. I’ve had customers who can’t stand Generac and swear by Kohler.
I don’t drink corporate Kool-Aid, but Kohler should take some lessons from Generac on how to design a unit.
