MC/BX/AC, please clarify. Also, what cut and bush do you use?
Aluminum jacket BX (AC cable) is popular now around here. It is light. Its jacket prover Ofer a decade so it does not separate when pulled.
BX connectors have to be designed for AL tho. Many guys use set screw bx connectors which bothered me but then I saw set screw connector listed for AL jacket.
I should have said in post #18 that yes AC Is in the same category as MCAP as far as not having a wire EGC to terminate. Around here AC is so rare, most people don't even know it's a thing and will say something like "you mean bx? No you can't get that anymore".
Curious, how does the cost of AC compare to 12/2 MC where you are?
Does anyone have any docs or vids on terminating MCAP? It's pretty interesting, though I will admit even MCAP would make me less confident in the EGC just due to the flimsy nature of MC. Give it a little tug and the cable splays out in a mile of sharp edges.
As for the bushings and connectors, I honestly haven't done enough of it to even cite the brand or type of connectors, but I do know they had a hard inner corner, no radius, and just trying to turn wire 90* in a panel was asking for it. Never such issues with NM.
The split bushings (red heads) are a JOKE! The split is exactly where wire will go, and right to a sharp metal edge of the MC. The clad is thin, there is no way to "remove the bur". The bushings never stay in place, and I could design something in 20min that is better, but I also think I am not the only guy that has run into this. Maybe better products exist.
I called the most reputable supply in 5 Boris of nyc now and he said same price for any 250’ roll. I am surprised as well. Bx, mc steel or aluminum jacket 1$ difference . 160$ per 250’ roll.
Right after pandemic I know there was a difference between steel and aluminum jackets.
I have never had those problems. The chosen bushings should be large enough that the ends overlap when pushed into the sheath, and turned so the split is 180 deg. from the cut ends of the metal.
And I have no trouble re-shaping the cut ends of the sheath so there is no sharp edge against the wires even without a bushing. I use bushings with AC/BX and FMC, but not with MC, with its plastic liner.
I have also not had those problems. The connector should retain the redhead. Maybe you were using the wrong connectors?
Count me in as a member. How is it any different than the Romex cult with the bare EGC?
-Hal
Well you need an EGC. How would one provide and EGC without using a wire for NM? If the sheath is metallic, why not make that the EGC? Seems like a waste to provide a wire, not only for material cost but then more labor of terminating it.
MC, with its separate insulated EGC was developed to be an armored cable that does away with the problems of the connectors and armor being used to provide EGC continuity like AC does. It is bullet proof. But I guess after some time, the guys who used AC and were switched to MC got annoyed with having to deal with another conductor, so some MC was watered down to again use the armor and connectors for the EGC. Why bother? Just use AC to begin with.
-Hal
Uggh! How about the manufacturer recommended Roto-Split? Sure, maybe a bit more work but you get a clean armor cut because it cuts with a saw blade at the proper angle.
-Hal
The 1104's make a real nice cut, much better than dykes.
. Oh? Just like all the "problems" there have been with using EMT as an EGC? I don't think there have been any problems with either it's just the grounding obsession cult
Yeah I don't really see what niche MCAP is supposed to fill. Isn't that what AC is for? It does have a much bigger bonding strips/conductor so maybe it has a lower impedance fault path.
Isn't the conductive sheath a redundant grounding pathway along with a wire EGC in certain cable types?
All I can say is if we are connecting sensitive gear, we never just rely on the raceway as a low impedance ground path. Not really from a personnel safety perspective, but equipment.
As for cutting MC, as mentioned, I have not used it enough to be a 'pro MC guy', but I quickly adapted to my electric dotco. In manufacturing, I lived with one in my hand so I can deliver surgical precision with that. At least, IMO, better than that roto thing. I cut at an angle.
BX is actually a brand name for the first commercially available AC when it came out around 1910. It was made by a company called Sprague Electric, who was experimenting with two new methods of making a type of cable with armor on it, instead of using K&T. The “X” meant “Experimental” and they made two versions; A and B, but only BX was released to the market. Sprague Electric was bought shortly thereafter by GE, who trademarked the term “BX” as their brand of Armored Cable or “AC” as it later became known generically. So BX and AC are the same thing.
I think that Southwire now owns the trade name “BX”, just like they own the term “Romex” for NM cable.
What exactly is "sensitive" equipment? There is a lot of talk out there about " sensitive electronics" or things acting wacky if they don't have a "good ground". It's all nonsense.
Years ago I was in a old basement doing some troubleshooting of a burning electrical smell when my flashlight died, only then in the dark did I notice a slight orange glow to some BX cable in the corner. The cable was faulted and glowing slightly, breaker never tripped.
I don't disagree that half the industry info is flaky at best. As far as sensitive electros, I work around CNC machines. If you have never been around, picture about 5 super computers, several VFDs, about 20 SMPS, tons of serial encoders, and the list goes on. They are certainly industrial, but usually 6-8 figures new, so.....if a piece of wire can potentially protect it, it gets done.
