electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
1. We have mostly used a third party energy usage monitor that has solar capability on out systems. I am doing my first enphase system and we would still like to use this system. An enphase gateway is not cheap so I would prefer not to buy one in addition to this other setup. Is there anything I need a gateway for as far as any commissioning or setup? What about future updates or troubleshooting? Would you consider it kinda hack to not supply one?
2. With an IQ combiner or gateway, what are the CT's for? AS far as production, cant it just add up all the inverters' output to give you the total? Why production CT's. Then the consuption CT option, what do those accomplish? I assume just so you can see you total net usage or production?
3. IF I am using just the gateway, can that go anywhere and just get plugged into AC power or do the inverter output circuits need to pass thru it? (probably related to #2)
