TwistLock
- California
- Electrician
Doing an Eaton flex retrofit and had a question about Common vs Independent trip with regards to MWBC’s.
For (quad) breakers I understand that 2 pole ‘common’ trip means ‘internal’ automatic trip of both poles (2 out of the 4 in breaker in this case) as well as handle ties. Whereas 2 pole ‘independent’ trip means handle tie(s) only.
It’s my further understanding that for a MWBC only ‘independent’ trip is required using handle ties. True?
If true, is there any reason I couldn’t use a 2 pole ‘common’ trip for a MWBC as well ?
