Sparky2791
- Northeast, PA
- Electrical Design
Hello -
Preparing a drawing for the EC to hook up this piece of manufacturing equipment and the manufactures information listed this....
The machine is from overseas. Not sure which country.
Trying to determine any specifics as to what makes it class C grounding.
Are they seeking a separate ground rod(s)driven at the equipment for this to meet the 10 Ohms or less? We are pouring a new slab where the machine will be located which will have new re-bar doweled into the existing slab but new rebar will not be tied to the existing so ultimately not part of the GES of the building.
I looked up Class C grounding and it talks about grounding for 300V and below and so far on the equipment info we were given I do not see the voltage of it listed. In my experience these are typically 480V 3 phase.
Could go 'down a rabbit hole' on the web but thought I would start here and tap into the vast knowledge this site has.
Thanks for the replies!
