bob_stemple
- LHC AZ
- retired
I need 240v 20a outlet in the garage for a HF amplifier that will draw 10a. I'm wondering if this setup would be a safe way to go. Since I already have 240v 30a hot water tank in the garage, I would like to add a transfer switch (on-off-on) in the garage using a GE 100 Amp 240-Volt Non-Fused Emergency Power Transfer Switch and take the wiring from the hot water tank and connect to the load side of the transfer switch. Then wire one side of the switch to the hot water tank and the other for the outlet to run a hf amplifier that would draw 10a max.
