Prototype1
- Kansas City
- Noob EE
Can you please help and review this? I am the only EE at my job and not sure If I am doing it right. This is my first time sizing a PV panels.
Load Analysis for PV Panels:
Load analysis for the public latrine in the park, calculate the total electrical load of the building. Calculate the load of each device:
- GFCI Two duplex receptacles (men's and women's restrooms): 2 x 2 x 120V x 20A = 960W (assuming 20A per receptacle)
- LED lights: assume 10-15 LED lights, each consuming 10W = 100-150W (let's use 125W)
- Blow hair dryers: assume 2 hair dryers, each consuming 1500W = 3000W (let's use 3000W)
- Exhaust fans (2 x 50 CFM): assume 2 fans, each consuming 50W = 100W (let's use 100W)
- Small boiler: assume a small boiler consuming 2000W = 2000W (let's use 2000W)
- Calculate the total load:
- Total load = 960W (receptacles) + 125W (LED lights) + 3000W (hair dryers) + 100W (exhaust fans) + 2000W (boiler) = 6185W
- Determine the load factor:
- Load factor is the ratio of the average load to the peak load. For a public latrine, a load factor of 0.5-0.7 is reasonable. Let's use 0.6.
- Adjusted load = Total load x Load factor = 6185W x 0.6 = 3711W
- Determine the required PV array size:
- To determine the required PV array size, we'll need to calculate the total energy consumption per day.
- Assume the public latrine operates for 12 hours a day (8am-8pm).
- Total energy consumption per day = Adjusted load x Operating hours = 3711W x 12h = 44532 Wh or 44.53 kWh
- Determine the PV array size:
- To calculate the required PV array size, we'll need to know the peak sun hours (PSH) available at the site. Assume an average PSH of 5 hours per day.
- Required PV array size = Total energy consumption per day / PSH = 44.53 kWh / 5h = 8.91 kW
- Select the PV panel size:
- Let's assume we'll use a standard PV panel size of 300W.
- Number of PV panels required = Required PV array size / PV panel size = 8.91 kW / 0.3 kW = 29.7 panels
- To account for efficiency losses and other factors, let's round up to the nearest whole number. We'll need approximately 30 PV panels.
- 30 PV panels x 300W each = 9 kW total capacity
- Array configuration: 5 rows x 6 columns (30 panels total)
- Inverter size: 9 kW or larger to accommodate the total PV array capacity
