If I read it right, the difference between the Oregon Traffic light guy Mats and the Paul Tapple case in Washington, is Mats never said he was an 'engineer' in his job title, he was just challenging a math formula in court, and the engineering board was trying to gag that, saying nobody can do math in court unless your a PE. LOL it was a gross overreach of the state!Yeah, but then you have boards that go too far in enforcement and need to be slapped down by the courts: https://ij.org/press-release/oregon-engineer-wins-traffic-light-timing-lawsuit/
I do have a problem with the titles "architect" and "engineer" being applied in a slapdash manner just to make the job sound more important (the late George Carlin had a great sketch about this), but I would argue that "architect" is a very good description, and "engineer" an acceptable one, of what a lot of networking teams do. Just because they're designing data links instead of buildings doesn't diminish the amount of learning and thought necessary.
The case in WA was Paul Tappele, a professional Civil Engineer, and his firm Fisheries Engineers, Inc. sued the State of WA because it was allowing state employees to use the title “Engineer” even though they were not licensed or registered as engineers, and some did not even have an engineering degree at all.
That depends on the laws in your state, in Washington State where the Paul Tapple case wasIt does not unless you completely ignore the context and language construction. The person controlling a railroad locomotive is called an "engineer" but is not a PE (although they may have an operator's permit for the machine), nor are many "chemical engineers" licensed PE's, either.
Revised Code Of Washington (RCW) Chapter 18.43 defines “engineer” to mean a “professional engineer” and provides in part that “In order to safeguard life, health, and property, and to promote the public welfare…it shall be unlawful for any person…to use in connection with his or her name or otherwise assume, use, or advertise any title or description tending to convey the impression that he or she is a professional engineer or land surveyor, unless such person has been duly registered under the provisions of this act.”
That ruling in WA had effects on a local power company here, the power company would put "Distribution Engineer" on the business cards of people then send out to look at new services.
However the job did not even require an engineering degree, so the cards got changed and anyone whom did not have a engineering degree got the title 'engineer' removed from their stationary and is now a 'distribution technician'
