10Driver
- California
- Retired
I was told set screw EMT connectors do not meet the 2023 NEC code but I cannot find any specific guidance one way or another. The conduit is inside an aircraft hangar, not being used for ground purposes and is definitely not in a wet location defined by the NEC. Are EMT compression fittings required in this case or do the set screw fittings meet code?
