emiller233
 - pittsburgh, pa
 - Controls-Automation engineer
industrial application, inside of a seacan shipping container. I'm not sure where to even start looking in the code book.
The customer wants us to run qty=(4) 480VAC multi-conductor cables in wire mesh basket tray, which I'm not extremely knowledgeable about it yet.
XLP Insulation, PVC Jacket, 600/1000V UL Type TC-ER, 90°C
- Is there a minimum height requirement?
 - is a cover/lid required, if so, when?
 - not sure on this one since its an 'open' cable tray. But I think the cables have to be separated by the same distance as the diameter if said cables. EX: scale is 3/4" so need a 3/4" space between it and the next cable.
- but they can be touching if we derate them?
 - is a barrier required to separate it from 24VDC control voltage and/or ethernet communication cables? assume all cables have 600V rated insulation.
 - And anything else im not thinking of at the moment and listed on the list of questions?
