Good morning everyone, I’ve been getting an influx of service upgrades recently and in the past, I’ve always updated the range & dryer wires to being 4 wire. I’d make the service disconnect outside, move all the bonding and grounding to the outside enclosure, resulting in the inside panel being a sub panel. I’m in Massachusetts which means they did away with 250.140 (B) (5) being an option for the dryer & range bonding. Sometimes updating the wires are easy, sometimes they can be a headache. With that said, I was curious if anyone else had an efficient setup allowing the existing 3 wires to remain in place, example what type of listed emergency disconnect (not service disconnect) are you using? The plan would be using a standard meter, running SEU to an emergency disconnect, then continuing into the house panel with SEU, and doing all the bonding & grounding in the panel inside, adding the correct labels on disconnects and panels, and making it complaint. I just wasn’t sure the best enclosures people have found or setups have worked best for them in the past. I know milbanks are only listed for use as service equipment only. Model numbers are appreciated! (Sorry, I’m more on an industrial guy and want to be more fluent and efficient on the residential side of things) Cheers!
