- Chapel Hill, NC
- Retired Electrical Contractor
If you come across 12/2 BX cable that doesn't have that steel wire then we know it cannot be used as a ground.  However, it is inherently already grounded and can carry a fault.  The code will not allow us to use the cable as a grounding conductor.  If I install a gfci and then install receptacles with a ground then am I not, inherently, using the ground?
The ground on the receptacle is connected thru the screws that attach the receptacle to the box and then to the cable. Indirectly are we creating a hazard by allowing 3 wire receptacles on a BX cable without the inner steel wire?
