The nameplate of a Syncrowave 350LX Arc welder (Cant figure out how to attach photo) does not specify an Effective (eff) or a Max current value. So I'm of the assumption (
) That the Current value given on the nameplate (i1) is the primary rated current at its given voltage.
It will be wired 240V (230v) and shows an i1 of 131.1A.
Its my understanding that duty cycles can be adjusted by the the person welding when adjusting the output amperage, And the nameplate represents this showing multiple duty cycle percentages at different output currents (i.e. 30% @ 400A, 40% @350A ... , 100% @ 250A).
The question is how to determine the duty cycle to use in Table 630.11(A) when given primary rated current, and adjustable duty cycles.
Questions solve ignorance.
Thanks in advance,
- Ian
Thanks in advance,
- Ian
