Wrabbitslayer
- Arkansas
- Industrial Electrician
Hello, I am an industrial electrician. Most of my experience has been with existing installations but I have ran services for new equipment also. I have been approached by the local volunteer fire department asking me to hook up a backup generator they received from the USFS. The generator is a 60 Kw 3PH military surplus, see attached data plate. This is outside the scope of what I usually do so I'm needing some advise. The fire department has a 200A panel inside with the 2 largest loads being an electric range and the compressor they use for filling their SCBA tanks.
I intend to go from the Gen to a transformer then inside the building to a manual transfer switch. I am at a complete loss what type and size transformer I need. Also, What would be an appropriate transfer switch. They have a very limited budget so are wanting it done as cheaply as possible. Any help y'all can give me would be greatly appreciated.
https://postimg.cc/gallery/FmK44df
