brycenesbitt
- United States
For you code buffs, here are the San Francisco amendments to code:
For example
"(E) Wiring for temporary theater stages and platforms, motion picture and television studio sets supplied from approved electrical outlets installed for the purpose." 89.121 Work Exempt from Permits.
"The building Official shall have the authority to disconnect electric service to a building, structure, property or equipment regulated by this code when it is necessary to abate a serious and imminent hazard to the life"
"410.36(B) All luminaires or luminaire outlets supported by suspended ceiling systems shall have supplemental support wires (minimum #12 gauge) connected from the fixture housing or fixture support bracket to the structure above." (Earthquake Country).
"378.12 Uses Not Permitted. Nonmetallic wireways shall not be used in the following:
(6) Where the voltage of the contained conductors is in excess of 50 volts."
"358.12 Uses Not Permitted. EMT shall not be used under the following conditions:
(3) In concrete slabs on grade."
ELECTRICAL CODE 2022 Edition
Legal publisher offering ordinance codification services for local governments, specializing in providing codes of ordinances in print and on the Internet
codelibrary.amlegal.com
For example
