So I just got done watching this more than an hour long video. As far as I understood, in a building with lots of equipment, lightning can induce voltages into insulated conductors and to prevent cross arcing you ground the metal equipment to the ground to so it has a place to dissipate to. But then later in the video it's talking about how you should not just install ground rods everywhere (auxiliary electrodes) so it doesn't try and travel through equipment and dissipate through a separate equipment ground.
At first I thought ok, then just install grounded electrode conductors to a grounding electrode in a ungrounded system, because those don't have a place to dissipate the induced voltage, however on a second video of his he says grounded AND ungrounded systems. Then later on on that second video I understood it as bond everything metal, and give it just one solid grounding electrode. Which is it?
As a separate remark, he focuses on induced voltage in transformer windings due to a magnetic pulse from lightning - but wouldn't the transformer enclosure act as a faraday cage, and in essence no magnetic field should get inside to produce that induction? I get it in cables outside, because they're unsheathed, or maybe in plastic conduit. Anyway, just an observation.
