I’m having a continual problem of 120 V/15 amp conveyor toasters heating up at the plug and burning the receptacle. These things run continuously every day, so I changed them out to hospital grade 20 amp GFI receptacle, hoping that the stronger tension would solve the problem, but it burned out that one as well. Any good solutions? I was thinking about just cutting off the plug off the cord and hard wiring it directly inside a four square metal box with a GFI blank device or GFI breaker protecting it. Has anybody else had this issue? Do you think a twist lock plug would be better than hardwire?
